Button | Description | |||||
Saves currently displayed image to a selected file. | ||||||
Clicking the "arrow" icon next to the Save button displays the following available options: Save– Saves currently displayed image to a selected file. Save all– Saves each multipass (including the Beauty pass) as a separate file using a specified file format. Save CXR – Stores all the information from the VFB (all render elements, including the LightMix, tone mapping, denoising data, etc.) inside a single CXR file. | ||||||
Copies the VFB content to the host app frame buffer. | ||||||
Copies currently displayed image into clipboard. | ||||||
Erases currently displayed image. | ||||||
Activates mode for editing the render regions. | ||||||
Clicking the "arrow" icon next to the Render Region button displays the following available options: Disable All – Disables all selected regions. Delete all – Removes all selected regions. | ||||||
Activates pick mode for selecting objects and setting of camera focus point. | ||||||
Hides/shows tools sidebar. | ||||||
Stops the rendering process without discarding any additional data or post-rendering actions.
Clicking the "arrow" icon next to the Stop button displays the following available options: Stop – This is the same as the "Stop rendering..." button in the Cinema 4D Picture Viewer window. (this is the default action for the Stop button) Cancel – Stops the rendering process, discards denoising or post-rendering actions, and skips saving output files (if were set up). | ||||||
Starts the production rendering process. | ||||||
Clicking the "arrow" icon next to the Render button displays the following available options: Render – Starts rendering process. (this is the default action for the Stop button) Start IR – Starts Interactive Rendering. Resume last – Resumes last render. Resume file – Resumes rendering based on a previously saved CXR file. | ||||||
This drop-down list allows selecting the multi-pass to be displayed in the VFB. | ||||||
This drop-down list allows performing zoom actions. Zoom in – Zooms the image in. Zoom out – Zooms the image out. Zoom to 50% – Zooms the image to 50%. Zoom to 100% – Zooms the image to 100%. Zoom to 200% – Zooms the image to 200%/ Lock IR resolution – This checkbox locks the image aspect ratio when the IR is running.
Start Interactive Rendering – Starts the Interactive rendering feature. | ||||||
Clicking the "arrow" icon next to the Render button displays the following available options: Render – Starts rendering process. (this is the default action for the Stop button) Resume last – Resumes last render. Resume File – Resumes rendering based on a previously saved CXR file. | ||||||
Post Tab
Section | |||||||||||||||||||||||||||||
Section | ||||||||||||||||||||||||||||||
History Tab
Section | |||||||||||||||||||||||||||||||||||||||||||||||||
LightMix Tab
Collab Tab
