In VFB 2, it is possible to compare images with different resolutions or aspect ratios.
UI Text Box
type
note
VFB 2 provides two options to open CXR files: by using the history tab or through the drag-and-drop feature.
UI Expand
title
Click here to see the option to open CXR file from the History tab...
UI Expand
title
Click here to see drag-and-drop option...
Button
Description
Stores content of the current VFB into the history.
Loads content of selected CXR file in the history.
Disables the history comparison and shows only the current render.
Shows currently rendered image.
Removes all items from the history and optionally from HDD.
Show with the original postprocessing – Determines which postprocessing is used when comparing images: the one used when the original image was saved or the one currently used in the VFB Post tab.
Button
Description
Show and Edit this image.
Save current render element.
Resume rendering of the current scene using this history item as starting point.
Clear this item from history, but do not delete it from file system.
Delete this item from history, and also from the file system.
Uploads this item to Chaos CollaborationCloud.
width
5%
width
40%
width
55%
Starting from Corona 12 Update 1Collaboration features from Chaos Cloud Collaboration is are supported in Corona for 3ds Max. With Cloud the Collaboration tools, you can easily share drafts and final renders with customers and team members. The Collaboration tools from Chaos Cloud Collaboration also supports mark-up discussions, version control, and more, allowing for efficient and seamless project coordination in real-time.
To learn more about how to use Collaboration features from ChaosCloudCollaborationplease visit this page.
