This page provides information on the V-Ray Color Picker and its Color Assistant.
The V-Ray Color Picker is a color manager that allows numeric color value selection in Screen (sRGB) and Rendering (RGB) or Rendering (ACEScg) Color spaces depending on the global setting (Settings > Render Parameters > Color Management).
The V-Ray Color Picker has a Color Assistant that provides color palettes to pick a color from. The Color Assistant can be opened when you click on the side bar at the bottom of V-Ray Color Picker window.
UI Path
||V-Ray Asset Editor|| > click on any color slot
Section | |||||||||||||||||
Example Workflow
