This page provides information about the Chaos Bridge menu in Chaos Bridge for Rhino.
width
60%
Chaos Bridge is available as a menu in Rhino's top menus.
UI Text Box
type
info
The export of V-Ray Scenes is available without a license.
width
5%
width
35%
Click on the image to enlarge it.
Options
width
60%
Export VRScene – Exports a .vrscene file.
Enscape Compatibility – When enabled, Enscape data such as materials, assets, and lights are exported into the .vrscene file.
UI Text Box
type
note
Enscape and V-Ray data are exported following the V-Ray for Rhino logic. To edit this data, install the corresponding Chaos plugin used for authoring it.
