width60%
The Emissive material settings are organized in Basic and Advanced modes. Switch the mode from the toggle button under the Preview Swatch or globally from the Configuration rollout of the Settings tab.
The Add Layer andAdd Attribute buttons are provided for some V-Ray materials, including Emissive. For more information, see theAdd Attributeand Add Layer sections.
UI Text Box
typetip
Holding down Ctrl while having the Add Attribute or Add Layer menu open, allows selecting multiple entries without closing the dropdown.
The context menu of the Color slot provides options to Copy and Paste, as well as to Reset the color.
A Reset option is provided in the context menu of each Number Slider.
width5%
width35%
Image RemovedImage Added
Emissive
width60%
Some options are available only in Advanced mode.
Color – Specifies the color of the light. A texture can be specified as well. See the Color and Texture examples below for more information.
Intensity – Controls the strength of the light.
Transparency – Specifies the color that is transparent. For this parameter black stands for opaque and white for transparent color. A texture can be specified as well. See the Transparency Texture example below for more information.
Emit On Back Side – When enabled, the object emits light from its back side as well. When disabled, only the front side emits light, and the material renders as black on the back sides. See the Emit On Back Side examples below for more information.
Compensate EV – Used when rendering with the V-Ray Physical Camera. When enabled, the intensity of the material is adjusted to compensate for the camera exposure.
Color *Opacity – When enabled, the color of the light material is multiplied by the opacity texture. Otherwise, the color and opacity act independently (so-called additive transparency).
width5%
width35%
width30%
width40%
Before after
afterLabelOn
beforeLabelOff
Panel
Panel
width30%
Intensity: 10
Color: Blue
Viewport Display
width60%
Viewport Texture
The selected texture is displayed in the viewport
Keep in mind that procedural textures are not shown in the viewport, however, any Bitmap textures, including ones nested in procedurals, will be automatically displayed.
width5%
width35%
Image Added
Override Control
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
Expand
titleTranslucency
Translucency
Multiexcerpt include
SpaceWithExcerptVRHINO
MultiExcerptNameTranslucency Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Translucency Attributes
Expand
titleBump
Bump
MultiExcerptNameBump Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Bump Attributes
Expand
titleContour
Outline
MultiExcerptNameOutline Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Outline Attributes
Expand
titleDisplacement
Displacement
MultiExcerptNameDisplacement Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Displacement Attributes
Expand
titleRaytrace Properties
Raytrace Properties
MultiExcerptNameRaytrace Properties Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Raytrace Properties Attributes
Expand
titleOverride
Override
MultiExcerptNameOverride Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Override Attributes
Expand
titleMaterial ID
Material ID
MultiExcerptNameMaterial ID Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Material ID Attributes
Layers
