width60%
Generate caustics – When enabled, the material generates caustics.
Receive caustics – When enabled, the material receives caustics.
width5%
width35%
Viewport Display
width60%
Viewport TextureSelected Bitmap The selected texture is displayed in the viewport and it overrides all other material parameters. The viewport texture does not affect the way the material is rendered with V-Ray. It is mainly used for preview purposes.Keep in mind that procedural textures are not shown in the viewport, however, any Bitmap textures, including ones nested in procedurals, will be automatically displayed.
width5%
width35%
Image RemovedImage Added
Override Control
