width60%
Some parameters are only available in Advanced mode.
Mode – Specifies one of the following methods for adjusting textures.
Multiply – Multipliers can be specified to adjust colors and textures.
Blend Amount – Blend amounts can be specified to adjust colors and textures.
Overall Color – Controls the intensity of the Overall Color, which acts as a color multiplier for all color components in the material.
Transparency – Controls the intensity of the Transparency.
Diffuse Color – Controls the intensity of the diffuse component color of the shader.
Primary Spec. Color – Controls the intensity of the Primary Specular color component, which corresponds to the light reflected off the outer surface of the hair strands.
Secondary Spec. Color  – Controls the intensity of the Secondary Specular color component, which corresponds to the light reflected off the back surface of the hair strands.
Transmission Color – Controls the intensity of the Transmission color component, which corresponds to the light that passes through the hair strands.
width5%
width35%
Viewport Display
width60%
Viewport Display – Enables connection/binding between V-Ray and the corresponding base application material.
Color – Enables color binding. Changing the V-Ray material color changes the corresponding base application material color and vice versa.
Opacity
–Enables refraction/opacity binding. Changing the SketchUp material opacity
changes the V-Ray material
refraction and vice versa.
Texture Mode – Enables texture binding. Changing the V-Ray material texture changes the corresponding base application material texture and vice versa
Disabling this parameter allows
for base app material
changes without affecting the V-Ray material.
Auto – Binds the diffuse texture to the base app material.
UI Text Box
typeinfo
In this mode complex texture networks are baked to a single image used as a viewport preview. Differences between the rendered result and the viewport preview may occur due to the fact that only the texture confined within the 0 to 1 UV square is baked. This affects most procedural patterns and textures with custom UV placement configuration. Raytraced and Tri-planar textures are not supported.
UI Text Box
typetip
It is recommended to save all raw bitmap buffers (textures embedded in SketchUp like SketchUp library materials textures) to disk before activating the Bake mode to preserve them.
The viewport resolution of procedural textures can be set globally from ||Extensions|| > V-Ray > Preferences > Viewport Texture Resolution option.
Custom – A custom texture slot is bound to the base app material.
Viewport Texture – The selected texture is bound to the base app material. Keeping this slot empty in Custom mode shows a Helper Texture in the viewport.
UI Text Box
typeinfo
If a Generic material contains multiple layers, only the top-most one is regarded in Auto binding mode.
width5%
width35%
Image Added
Override Control
Can be Overriden – When enabled, the material can be overridden when you enable the override color option in the Global Switches.
Attributes
The attributes from the following expandable menus are available for the Hair material.
