width60%
Generate caustics – When enabled, the material generates caustics.
Receive caustics – When enabled, the material receives caustics.
width5%
width35%
Binding
width60%
Texture – Allows the user to display the selected texture in the viewport. Keep in mind that procedural textures are not displayed.
width5%
width35%
Image Removed
Override Control
Can be Overridden – When disabled, the material is not overridden by the Material Override option in the Render Settings.
