To run V-Ray, you have to:
Progress Bar Container
step1
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
urlInstallation
titleStep 2: Activate your Product
urlActivate your Product
This guide provides steps on installing V-Ray for Blender.
The V-Ray installer can be unpacked and used as a portable version. See the Portable Installation for the workflow.
Please check the system requirements before installation. The V-Ray installer will automatically remove any previous versions.
Panel
borderColor#42BEFF
borderStylesolid
width40%
   Download the V-Ray for Blender Beta
UI Button
colorblue
newWindowtrue
icondownload
titleGet the V-Ray for Blender Beta
urlhttps://dev.try.chaos.com/beta/blender
width5%
Div
styledisplay: table-cell; border-left: 1px solid; color: #42BEFF;
width5%
width47%
Take the Blender Setup survey, so we can improve your V-Ray for Blender experience.
UI Button
colorblue
newWindowtrue
iconedit
titleTake the survey
urlhttps://chaos.surveysparrow.com/s/v-ray-for-blender---beta/tt-DsNrd
Running the Installer
Chaos License Quick Start Guide
UI Steps
UI Step
width60%
Welcome
Once you've carefully read the License Agreement and the Privacy Policy, check the boxes next to them, if you agree to the terms.
Proceed to click the Install button and wait for V-Ray to complete the process.
width5%
width35%
Image Added
UI Step
width60%
V-Ray installation is successful.
Participate in the improvement decisions for future versions of V-Ray. When agreeing to participate in the feedback program, no intelligence property is violated. Chaos does not gather scenes, assets, materials, etc. This preference can be changed anytime from within the interface. For more information, see the Chaos Telemetry page.
Anonymized Telemetry – Includes the most used product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
Personalized Telemetry – Includes the most used product functionality and parameter values but also contains personally identifiable information tied to an individual user's license
url
. This helps Chaos tailor and optimize the product for better personal use.
width5%
width35%
Image Added
Advanced Steps
width62%
If you want to customize your V-Ray installation, click on the Advanced button at the beginning of the installation process and follow these steps.
Panel
borderColor#ffda80
borderStylesolid
The Advanced installation method is not recommended for beginner users. If you have clicked Advanced by mistake, please go back using the navigation buttons at the top-right of the installation wizard.
width37%
width25%
Image Added
width38%
width5%
width33%
Image Added
UI Steps
UI Step
width60%
Directories
Here, you can specify the installation paths. Please check if the default folders are correct.
Add firewall exceptions – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you will need to manually add firewall exceptions later.
width5%
width35%
Image Added
UI Step
width60%
Licensing
In this step, specify whether the Chaos License Server runs locally or on another machine.
If you select Remote licensing, you have to enter the IP address of your Chaos License Server in the Primary License Server field. Leave port 30304 unchanged. An Alternate License Server can be used for redundancy in case the primary one does not respond. The License Server will not install when the Remote option is selected. When Local licensing is selected, the Chaos License Server is installed with V-Ray.
width5%
width35%
Image Added
UI Step
width60%
At this step, you can choose where to install the Chaos License Server.
Migrate data during installation – When enabled, it transfers all of your settings made with older versions of the License Server, such as proxy settings, etc. Disabling this option makes a clean install of License Server with any custom settings from previous installations reset to their defaults.
Add firewall exception – Allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you must manually add firewall exceptions later.
width5%
width35%
Image Added
Next Step
Go to step 2 to see how to load the V-Ray add-on in Blender.
step1
titleStep 31: Load Install V-Ray in Blender
urlInstallation
