width60%
V-Ray IES Light component creates a sphere light source. It can be connected to the V-Ray Render which automatically adds it to the rendered scene. If a list of input Positions is connected to this component multiple lights are generated.
width10%
width25%
Image Removed
Image Added
Input Parameters
On (Boolean) – Enables or disables the light source.Position
Plane (Point) – Sets the light source location (point position). If a list of input Positions is connected multiple lights are generated. Note: The number of input positions determines the lights count. Target (Point) – The light Position and Target combined determine the targeted light orientation vectorPlane) - The IES light base plane, where its origin is positioned and oriented along.
File (Path) – Specifies an .ies file to use for the current light.
Light (Generic Data) – Light output that can be connected to a Renderer component.
Example:
width10%
width80%
Image Added
IES Light component connection. Click on the image to enlarge it.
width10%
width10%
width80%
Image Added
width10%
