The Rigged models are now driven by our new Neural Crowd simulation system which is based on a new technology that uses Artificial Intelligence based on neural networks to achieve better realism and appeal in all situations.
Now you will find a new Download Status widget at the bottom-right corner of the 3D viewport that will give you all that information in realtime.
PROJECT SETTINGS DIALOG
In previous versions, it was possible to modify the
Units,
Texture quality, and the mode of the Resource Cache Mode of the project from the Project Properties panel. As these settings are not modified often, to optimize the UI space we have moved them to an independent Project Settings dialog …
…that can be accessed from the anima® Menu > Project > Settings option:
NEW DESIGN FOR THE “RESOURCE CACHE”
