The simplest way to control the pace of the animation is using the Speed multiplier parameter.
With it, we can slow down or speed up the velocity of the whole animation to easily create cool slow-motion or time-lapse effects.
width
5%
width
55%
Image Added
Animating the Time Offset
width
40%
For more complex time effects, since anima® 5.5.0, it is possible to animate with keyframes the Time offset value in 3ds Max.
width
5%
width
55%
Image Added
width
40%
This allows the simulation playback to be modified at will, using standard keys and animation curves, which greatly expands the possibilities for creating original non-linear temporal effects.
width
5%
width
55%
Image Added
width
40%
For example, take a look at the scene animation created by the custom animation curve applied to the Time Offset in the previous screenshot:
width
5%
width
55%
Multimedia
name
New-In-550-Playback-Control.mp4
width
100%
Static Motion Blur Effect
width
40%
The sameTime offsetanimable parameter can be used to apparently “stop” the motion of the actors by applying an animation curve set to linear and defining a time offset progression equal to the inverse of the real playback progression from the time bar in 3dsMax.
For example, if we have a scene of 200 frames at 25 fps (8s), we should set a key at frame 0 with value 8 and another one at frame 200 with value 0.
width
5%
width
55%
Image Added
width
40%
This setup will make the animated time offset to go backwards at the exact same playback speed as the source anima scene is going forward, resulting in the render of the same frame of the simulation on the anima scene.
The effect is similar to setting up a playback speed of 0, with the important difference that the neighbour frames (before and after the current one) are still able to be evaluated by the rendere, provide a proper Motion Blur effect on the 4D models.
Take a look at the result in the following video:
width
5%
width
55%
Multimedia
name
New-In-550-Static-Motion-Blur-Freeze.mp4
width
100%
width
40%
Using this method, you can replicate the effect that was used in the promotion video.
