The best way to bring yourcollision backgroundsto anima® is using thealive™ connection to send a list of 3D objects directly from your 3D application, using the anima® plugins. That is the easiest, quickest, and more efficient way to get your 3D geometries and start creating your simulations.
So, before continuing with this article and learning the manual way of doing it, make sure to take a look at the workflow with alive™ in the following documentation:
Widget Connector
width708
urlhttps://www.youtube.com/watch?v=lXqlgNMXLcQ
height398
