Align | ||
NEW 4D PATH TOOL
The new 4D path tool is the tool that creates the new paths compatible with the 4D Walking models. The new 4D paths can be drawn directly using the dedicated 4D path tool that is available in the toolbar, or can also be used by just dropping a 4D Walking model into the 3D viewport.
It works almost the same as the standard Path tool but has some important differences that are derived from the limitations that the 4D technology has. For example, there is no “generate” button for these paths, so you must place the models manually by dropping them wherever you want on the path. Also, they have limited interaction capabilities with the environment and will be ignored by the other crowd tools like the Avoid and Socialization areas or the Traffic lights.
