width57%
The V-Ray Al Surface shader is V-Ray's implementation of Anders Langland's alShader, which is designed to reproduce the appearance of skin. The current version takes into account diffuse reflection, two levels of reflection, and subsurface scattering.
If you wish to disable the material preview or adjust its quality to save processing power, you can do so from the Material Node.
width5%
width38%
