Fancy Bullets | ||
Note that this article applies to Corona and V-Ray plugins for 3ds Max and Cinema 4D only.
Compatibility
Which version of Scatter is installed with specific versions of V-Ray and Corona?
Anchor | ||||
Renderer | Scatter version | ||||||||||||||||
1.0 | 1.1 | 1.4 (15633) | 2.1* | 2.3 (17378) | 2.4 (17713) | 2.4 (19132) | 2.5 (18341) | 2.6 (19007) | 3.0 (19915) | 3.1* | 4.0 (21812) | 4.0 (21932) | 4.0 (22455) | 4.0 (24346) | 4.0 (24726) | 5.0 | |
Corona 8 | ? | ? | ? | ||||||||||||||
Corona 8 HF1 | ? | ? | ? | ||||||||||||||
Corona 8 HF2 | ? | ? | |||||||||||||||
V-Ray 6 (Max) | |||||||||||||||||
V-Ray 6.1 (Cinema) | ? | ||||||||||||||||
Corona 9 | ? | ? | |||||||||||||||
Corona 9 HF1 | ? | ? | |||||||||||||||
Corona 9 HF2 | ? | ? | |||||||||||||||
Corona 9 HF3 | ? | ||||||||||||||||
V-Ray 6.1 (Max) | ? | ||||||||||||||||
V-Ray 6.1 HF1 (Max) | |||||||||||||||||
V-Ray 6.1 HF1 (Cinema) | ? | ||||||||||||||||
Corona 10 | ? | ? | |||||||||||||||
Corona 10 HF1 | ? | ? | |||||||||||||||
Corona 10 HF2 | ? | ? | |||||||||||||||
Corona 10 HF3 | ? | ||||||||||||||||
V-Ray 6.1 HF2 (Cinema) | |||||||||||||||||
V-Ray 6.2 (Max) | ? | ||||||||||||||||
V-Ray 6.2 (Cinema) | |||||||||||||||||
Corona 11 | ? | ||||||||||||||||
Corona 11 HF1 | ? | ||||||||||||||||
V-Ray 6.2 HF1 (Max) | |||||||||||||||||
Corona 11 HF2 | |||||||||||||||||
Corona 12 | |||||||||||||||||
Corona 12 HF1 |
Legend
Means that the specific version of Scatter is released with the specific version of the renderer. | |
Means that the specific version of Scatter is compatible with the specific version of the renderer. | |
? | Means that the specific version of Scatter was not tested or cannot be tested with the specific version of the renderer |
. Usually, it means that a newer version of the renderer should be used (e.g. Corona 10 Hotfix 3 rather than Corona 10 non-hotfix). | |||||||
* | The Scatter version is released only for Cinema 4D and is not available for 3ds Max. |
Loading a
Specific Version of Scatter
Corona
To load a specific version of Chaos Scatter, follow these steps:
