Exposure– Auto Exposure in VFB 2.0 automatically adjusts the brightness of your render. Instead of changing settings like ISO, f-stop, and shutter speed yourself, Corona looks at the lighting in your scene and sets these values for balanced exposure. The strength of this effect can be controlled by the value of the slider. It also can be applied to the Simple Exposure in the Tone Mapping using the Bake.
White Balance– Auto White Balance corrects the color temperature in your scene. It automatically adjusts to remove unwanted color tints, making sure colors look natural no matter the lighting.It also can be applied to the White Balance in the Tone Mapping using the Bake.
Update during animation– This option updates the enabled Auto adjustment for each frame of the animation. This feature is especially helpful when the camera moves into a brighter area, such as from an indoor scene to a bright outdoor scene.
Tone Mapping
Saves current postprocessing settings into a file.
Loads postprocessing settings from specified file .
The Tone Mapping rollout lists the currentlyaddedTone Mapping Operators. By default, it includes the following operators:
Simple Exposure
White Balance
UI Text Box
type
note
Starting from Corona 12 Update 1, the White Balance operator has been deprecated and is now called "Legacy White Balance." The new White Balance operator uses Bradford's chromatic adaptation formula, which makes it more accurate and in-line with industry standard.
Green-Magenta Tint
Contrast
Saturation
ACES OT
"+" button– Displays the list of all available Tone Mapping Operators and allows to add one.
Reset button– Resets the current Tone Mapping Operators stack to the default configuration.
Presets button– Displays the list of built-in tone mapping presets.
width
5%
width
45%
UI Expand
title
Click here to see the full list of tone mapping operators...
