Saves current postprocessing settings into a file.
Loads postprocessing settings from a specified file.
Auto Adjustment
Exposure – Auto Exposure in VFB 2.0 automatically adjusts the brightness of your render. Instead of manually changing settings like ISO, f-stop, and shutter speed yourself, Corona looks at the lighting in your scene and adjusts these values for a balanced exposure. The strength of this effect can be controlled by the value of the slider. It can also be applied to the Simple Exposure operator in the Tone Mapping rollout using the Bake button.
White balance – Auto White Balance corrects the color temperature in your scene. It automatically adjusts to remove unwanted color tints, making sure colors look more natural no matter the lighting. The strength of this effect can be controlled by the value of the slider. It can also be applied to the White Balance operator in the Tone Mapping rollout using the Bake button.
Update during animation – This option updates the enabled Auto adjustment for each frame of the animation. This feature is especially helpful when the camera moves into a brighter area, such as from an indoor scene to a bright outdoor scene.
UI Expand
title
Click here to see the Auto Adjustment's UI...
Tone Mapping
The Tone Mapping rollout lists the currentlyadded Tone Mapping Operators. By default, it includes the following operators:
Fancy Bullets
type
circle
Simple Exposure
White Balance
UI Text Box
type
note
Starting from Corona 12 Update 1, the White Balance operator has been deprecated and is now called "Legacy White Balance." The new White Balance operator uses Bradford's chromatic adaptation formula, which makes it more accurate and in-line with industry standard.
Green-Magenta Tint
Contrast
Saturation
ACES OT
"+" button – Displays the list of all available Tone Mapping Operators and allows to add one.
Reset button – Resets the current Tone Mapping Operators stack to the default configuration.
Presets button – Displays the list of built-in tone mapping presets.
