Section | |||||||||||||||||||||||
Common Uses
The V-Ray Toon Render Element is useful for changing the appearance of a render in a compositing or image editing application. The vrayRE_Toon pass holds a mask for the toon outlines (the toon color is not present in it).
It has an option to invert its output so instead of white lines on a black background, we can get the opposite. It also supports opacity set from the toon effect.
Section | ||||||||||||||||||||||||
Section | |||||||||||||||||||||||||||
Fancy Bullets | ||
