width50%
The VFB is much more than a render image holder window. The new enhanced version provides a higher level of post processing adjustments and ability to modify your scene from inside the VFB. Here is a list of old and new benefits you should know:
  • Image preview:
    Loads render elements channels via a dropdown list;
    Works with display corrections;
    Loads various 8bit and 32bit file formats, including V-Ray resumable files;
    Image comparison between 2 or 4 renders;
  • Image management:
    Keeps the rendered image in full 32-bit floating point format;
    Can store history of rendered images with their post rendering corrections;
    Can save corrected output to various image formats;
  • Image editing and post processing:
    Set Color Corrections to rendered image and its elements;
    Composite mode for Back to Beauty workflow including layers corrections;
    LightMix control on lights contribution in the rendered image;
    Applying Proportion Guides on the rendered image;
  • Scene editing:
    Can modify actual lights values by transferring updated intensity and color from LightMix mode;
    IPR camera navigation and focus control from inside VFB;
  • Denoiser control;
    Region rendering control and test resolution;
    Allows you to choose the order in which the buckets are rendered;
    Automatic render resolution adjustment in IPR when the VFB window is resized;
To use the VFB for rendering, create a V-Ray Renderer node.
VFB also has some limitations which are listed in the Notes section below.
width5%
width45%
Image RemovedImage Added
VFB Menu
The V-Ray Frame Buffer menu holds the main frame buffer commands. Some of the options are also available in the VFB toolbar for a quick access.
Menu
Menu Options
File
Save current channel Saves the currently loaded channel to an image file format. Note that color correction layers are not saved.
Save all image channels to separate files – Saves all the render elements to separate files. Select the options (Image Added) button to open a menu with more settings.
Save all image channels to single file – Saves the image to a single multi-channel EXR or .vrimg file.
Load image – Opens an image file to be previewed in the V-Ray Frame Buffer.
Batch image processing – Allows processing of multiple .vrimg files with the same layer tree changes at the same time.
UI Text Box
typenote
With V-Ray 7, you can drag files directly onto the V-Ray Frame Buffer window to load them for preview.
Save all image channels to separate files options
Save VFB color corrections to render elements – When enabled, all color corrections are saved to the render channels (as opposed to only the RGB and effectsResult channels).
Input folder – Specifies a path to start images.
Output folder – Specifies a path for the output images.
Layer preset – Specifies a layer tree corrections preset.
Output filenames suffix – Specifies a suffix added to the output image filenames.
Overwrite existing – Enables overwrite of existing files with the same name in the output folder.
Render
Start interactive rendering – Starts IPR.
Stops rendering – Stops the ongoing rendering at its current state. It takes the render's current state as valid to perform all post-rendering tasks such as post-effects or image output saving.
Abort renderingStops Cancels the current rendering.
Render – Starts rendering.
Follow mouse – Renders the closest bucket found to the mouse pointer, when using the bucket image sampler. If the progressive sampler is used, V-Ray samples the closest pixels to the mouse pointer.
Follow mouse – Drag the mouse over the VFB while rendering to change what part of the image is sampled first;
Follow mouse (locked) – Locks the bucket (or sampling) starting point.
Copy current channel to clipboard – Copies the current channel to the clipboard. Shortcut: Ctrl+C
Clear image – Clears the contents of the frame buffer. This is useful when starting a new render to prevent confusion with the previous image.
View
Display color space –Specifies the color space, in which the image is displayed.
None – Does not specify a color space;
sRGB – Displays the image in sRGB color space;
OCIO – Displays the image in a color space loaded from an OCIO configuration file. See the VFB OCIO Control through Python for more information;
ICC – Displays the image in a color space loaded from an ICC configuration file;
Gamma 2.2 – Displays the image in Gamma 2.2 color space.
Zoom VFB – Zooms in/out the rendered image in the VFB.
Zoom 50% – Zooms out to 50%;
Zoom 100% – Zooms to 100%. Alternatively, double-click in the VFB with the left mouse button;
Zoom 150% – Zooms in to 150%.
Zoom to fit – Zooms the current image to fit in the VFB. If Render Region is active – zooms to the region.
Channels – Chooses which channels to see.
View red channel – Displays the red channel;
View green channel – Displays the green channel;
View blue channel – Displays the blue channel;
Switch to alpha channel – Displays the alpha channel;
Monochromatic mode –Displays the image in monochromatic mode.
Color clamping – Opens the color clamping submenu options:
Force color clamping – Forces color clamping;
View clamped colors – Displays the clamped colors.
Use pixel aspect – Enables visualization of the pixel aspect ratio.
Flip – Mirrors the image in the VFB. This is a view only option, the flipped image cannot be exported. This function is only active while holding the menu button or the hotkey for the corresponding type of flip. The effect does not interrupt interactive rendering.
Flip horizontally – Mirrors the image horizontally.
Flip vertically – Mirrors the image vertically.
Panorama View – Shows the image in 360° view.
Show History – Shows the History panel.
Show Layers – Shows the Layers panel.
Options
VFB settings – Opens the VFB Settings window where you can adjusts settings for Render View, Render Region, History, Layers, and Shortcuts.
VFB Toolbar
Image Removed
This dropdown gives access to render elements rendered for the scene. The selected render element is displayed in the VFB. By default, the RGB color and Alpha render elements are available. Any additional render elements that have been added to the scene also appear in the drop-down.
Displays the coordinates of the mouse pointer.
Specifies the sampled area size. Click on the arrow to open a context menu with the available sampled area sizes: 1x1, 3x3, 5x5, and 7x7.
Specifies the color of the pixel under the current mouse position before applying any color corrections.
Displays the RGB pixel values at the current mouse pointer position before applying any color corrections.
Specifies RGB values. Click on the arrow to open a context menu with the available option.
None – Does not specify the RGB value.
HSV – Specifies the Hue, Saturation and Value of the pixel under the current mouse position.
Web – Specifies the HEX of the pixel under the current mouse position.
8bit – Specifies the 8bit color palette of the pixel under the current mouse position.
Displays the Hue, Saturation and Value of the pixel under the current mouse position when HSV is selected.
Displays the HEX of the pixel under the current mouse position when Web is selected.
Displays the 8bit color palette of the pixel under the current mouse position when 8bit is selected.
Image RemovedImage RemovedImage RemovedImage RemovedImage RemovedImage RemovedImage Removed
Image Added
Locks the mouse pointer coordinates and displays information for the selected pixel.
Image Added
Shows corrected colors.
Image Added
Shows the V-Ray log.
Image Added
Displays the red channel.
Image Added
Displays the green channel.
Image Added
Displays the blur channel.
Image Added
Displays the Alpha channel.
Image Added
Saves the image to disk. Press and hold the icon to bring up the submenu:
Save current channel – Saves the current channel to an image file format;
Save all image channels to separate files – Saves all the render elements into separate files;
Save all image channels to single file – Saves the image into a single multi-channel EXR or .vrimg file.
Renders the closest bucket found to the mouse pointer, when using the bucket image sampler. If the progressive sampler is used, V-Ray samples the closest pixels to the mouse pointer. With this option enabled, you can right-click on the image and select Lock bucket starting point to lock the bucket (or sampling) starting point.
Allows you to render regions in the VFB. See the Render Region section for more information.
Image Added
Renders multiple polygonal regions in the VFB. See the Region Render section for more information.
Image AddedImage Removed
Starts IPR. If there is more than one camera in the scene, hold left mouse button to display a list of the available cameras.
Stops Cancels the current rendering. When the render is cancelled, the Denoiser is not applied or saved, equivalent to the behavior of the Cancel button in the Rendering window.
Image Added
Image Added
Starts rendering. If there is more than one camera in the scene,
Image Removed
Starts rendering. If there is more than one camera in the scene, hold left mouse button to display a list of the available cameras.
Render History
width50%
The V-Ray VFB keeps a history of previously rendered images, and lists each with a number, thumbnail, and textual details in the Render history panel. Up to four images can be called from the history to be compared in the VFB (as shown below). History files are stored as .vrimg files in a user-specified folder. Render history settings can be configured in
the VFB Settings window.
width20%
width60%
Image Removed
width20%
Image Removed
Image Added
Enables or disables image A/B vertical comparison. Select images A and B from the render history.
Image Added
Enables or disables image A/B horizontal comparison. Select images A and B from the render history.
Image Added
Enables or disables image A/B/C/D comparison. Select images A, B, C and D from the render history.
Image Added
Saves the current image from the VFB to the render history. The image is placed at the top of the render history list.
Image Added
Loads the selected image from the render history to the VFB.
Image Added
Removes the selected image from the render history.
Image Added
A search field where you can filter the images based on the scene paths and notes. The filter text is selected when pressing the Enter from the keyboard.
width5%
width45%
Image Added
width50%
UI Text Box
typetip
The keyboard keys from
UI Text Box
typetip
1 to 9 can be used to quickly load the first 9 images from the history to the VFB.
UI Text Box
typeinfo
Manually saved .vrimg files can also be added to the History folder, but they need to be saved with all image channels in one .vrimg file to keep the complete image info.
If the Render History is disabled, a link to the Settings History tab is displayed in the panel
width20%
width20%
Image Removed
The History panel with notes/name, resolution/time, and shortcut key info displayed. Right-clicking on an image in the VFB history brings up a pop-up menu with some useful options
width10%5%
width30%45%
Image Removed
Image Added
Image Info window
width20%50%
The History panel with notes/name, resolution/time, and shortcut key info displayed. Right-clicking on an image in the VFB history brings up a pop-up menu with some useful options.
Edit note – Allows you to add a text comment to the image; the comment appears below the image.
Set A – Sets the render as A image for A/B comparison.
Set B –  Sets the render as B image for A/B comparison.
Load to VFB – Loads the selected image in the VFB (same as double-clicking on the image).
Delete – Deletes the selected image from history. The image is moved to the system's Recycle Bin and can be restored from there if needed.
Load layers – Loads the layer tree preset of the selected image.
Load V-Ray settings – Loads the V-Ray settings used for the  saved render.
Compare V-Ray settings – Opens the Compare V-Ray settings dialogue, where you can compare the render settings of saved renders.
Copy scene path – Copies the full path to the scene.
Copy project path – Copies the full path to the project.
Reload history – Re-reads the history image list. This may be needed if the history folder is updated outside of Houdini (e.g. from another Houdini session).
UI Text Box
typeinfo
Layers
The redesigned V-Ray Frame Buffer includes a suite of color corrections and tools for adjusting the image. The tools are added as layers and displayed in a layer tree. You can enable or disable a particular tool using the visibility icon (Image Removed) to the left of its name.
For more information on using the Layers, see the Layers page.
width40%
width20%
Image Removed
width40%
Image Removed
Creates a layer. Multiple layers of the same type can be added.
Folder – Allows grouping multiple layers;
Background – Adds a background color correction layer;
Render Element – Selects a render element from your image that you can use in compositing. This is only available when the Source layer is set to Composite;
Constant – Adds a solid color that can be used to achieve an effect on another layer (for example to multiply by the constant);
Exposure – Adds an Exposure color correction layer;
White Balance – Adds a White Balance color correction layer;
Hue/Saturation – Adds a Hue/Saturation color correction layer;
Color Balance – Adds a Color Balance color correction layer;
Curves – Adds a Curves color correction layer;
Lookup Table – A Lookup Table layer allows loading a LUT file for color transformations;
Filmic Tonemap – Contains different types of mapping curves and gamma corrections. Also allows selection of a color space.
Integer mask elementMask is used with integer render elements like VRayRenderID, VRayObjectID, and VRayMtlID Render Elements.
MultiMatte mask elementMask is based on the MultiMatte Render Element.
Cryptomatte mask elementMask is based on the VRayCryptyomatte Render Element.
Proportion Guides – Adds a proportion guide layer.
For more information, see the Layers page.
Image Removed
Image Removed
Image Removed
Image Removed
Image Removed
Image Removed
Image info – Opens a window containing detailed information about the image, including, but not limited to Camera, Aperture, FOV, Target Distance, V-Ray version, render time, and also custom attributes specified in the exr metadata of VRayOptionRE render element. Have in mind that the camera values are saved in system units. Also, the vrayrevison info displayed in the list is not related to the saved .vrimg file but to the current V-Ray build installed for Houdini.
Expand
titleClick here to expand the Image info window...
Image Added
Image Info window
Save images as – Saves all images in the render history panel in a selected format.
Select all – Selects all images in the render history.
Select none – Deselects all images in the render history.
Select invert – Deselects the currently selected image(s) and instead selects all other images outside of the first selection.
UI Text Box
typetip
If you want to keep the layers that come with the Houdini scene, turn the Auto Load Layers option off from VFB > Options > History tab. If you want to load layers from an external image, enable the Auto Load Layers option and check how you save those images.
width5%
width40%
Image Added
width5%
Filters
width50%
The V-Ray VFB provides a variety of filter presets.
The Filters panel preset previews provide easy check of multiple color corrections scenarios. Preview thumbnails are auto updated on render end. Manual reload from the button or right-click option is needed for image load from History. Applying one of the filters, adds it as a folder on top of the layer tree. On the next filter load the top preset folder in the layer tree is replaced by the new corrections.
To create custom filters in the VFB Layers panel right-click on a folder containing correction layers and save it as a .vlpdir file. Change presets directory from V-Ray Frame Buffer Options menu > VFB Settings > Filter/Layer presets > Path. Personal custom filters are now shown in the panel and can be loaded quickly.
UI Text Box
typeinfo
Right-click on a folder in the layer tree to save it or to load an already saved set of color corrections.
Image Added
Refreshes the preview thumbnails.
Image Added
Image Added
A text search field which provides fast location of the desired filters. The filter text is selected when pressing Enter from the keyboard.
width5%
width45%
width50%
UI Text Box
typetip
Double-click on any preview thumbnail applies its preset folder to the layer tree.
UI Text Box
typetip
If you want the current corrections to be taken into account for the Filter thumbnail previews, disable the Ignore existing correction for the Filter thumbnails from V-Ray Frame Buffer > Options menu > VFB Settings > Filter/Layer presets.
If a Filters folder path has not been specified, a link to the Filter/Layer presets tab is displayed in the panel.
width5%
width45%
Image Added
Layers
width50%
The redesigned V-Ray Frame Buffer includes a suite of color corrections and tools for adjusting the image. The tools are added as layers and displayed in a layer tree. You can enable or disable a particular tool using the visibility icon (Image Added) to the left of its name. The Image Added icon indicates that a layer is disabled. All layers have a vertical line marker for clear differentiation between fixed and flexible layers. Fixed layers are marked with a grey line, while newly added layers, which can be moved around freely and put into groups, are marked with a blue line.
Image Added
Folder – Allows grouping multiple layers.
Vignette – Adds a vignetting effect to the image.
ICC Profile – The ICC correction allows you to apply an ICC profile to the image, so that (for example) it matches the appearance of the image in Adobe PhotoShop.
Lookup Table – A Lookup Table layer allows loading a LUT file for color transformations.
Curves – Adds a Curves color correction layer.
Color Balance – Adds a Color Balance color correction layer.
Hue/Saturation – Adds a Hue/Saturation color correction layer.
White Balance – Adds a White Balance color correction layer.
Exposure – Adds an Exposure color correction layer.
Constant – Adds a solid color that can be used to achieve an effect on another layer (for example to multiply by the constant).
Render Element – Selects a render element from your image that you can use in compositing. This is only available when the Source layer is set to Composite.
Background – Adds a background color correction layer.
Image alpha mask  The Image Alpha Mask is based on the rendered Alpha channel.
Image Added
Deletes the selected layer(s).
Image Added
Saves a layer tree preset.
Image Added
Loads a layer tree preset.
Image Added
Quick access to custom layer presets. You must set the path to it in the VFB Settings.
Image Added
Undo various actions related to layers such as create, delete, reorder or modify a layer.
Image Added
Redo various actions related to layers such as create, delete, reorder or modify a layer.
width5%
width45%
Image Added
width50%
Each layer has a context menu. Right-click to display it:
Command
Description
ResetResets all changes done to the selected layer.
SaveSaves the layer as a preset.
LoadLoads a preset for the selected layer.
DeleteDeletes the selected layer.
Save all CCs as LUTBakes all the color corrections to a LUT file.
New LayerCreates a new layer.
DuplicateDuplicates the selected layer.
Blend ModesSpecifies how the selected layer blends with the result from all layers below it.
width5%
width45%
Image Added
Stats
width50%
The V-Ray Frame Buffer allows monitoring of different statistics and information about your scene in the Stats panel. The exact contents of the Stats changes depending on the scene,  the rendering mode (interactive vs production, bucket vs progressive) and others.
UI Text Box
typetip
Right-click to display a context menu, allowing you to copy the Stats values.
width5%
width45%
Image Added
Log
width50%
The Log panel provides messages about the render process. Verbosity control is available and you can filter the type of messages shown in the Log: AllError OnlyError & Warnings, or Error, Warnings & info. Additional options are available when you click on the Open options Image Added button:
Show progress – Shows a completion percent of each task (e.g. building Light Cache).
Wrap – Wraps longer lines in order to avoid horizontal scroll.
Undock – Docks/undocks the Log tab.
Note that the V-Ray Log is also accessible via the Show log button.
The Log tab can be detached and used as a separate window or docked elsewhere.
UI Text Box
typetip
Ctr+F opens a search field at the bottom of the Log tab.
width5%
width45%
Image Added
VFB Shortcuts
These shortcuts navigate through the VFB image. Please note that the VFB window must have the current focus for the shortcuts to have effect:
DescriptionShortcut Key
GlobalShow/hide historyH
Show/hide only layers treeP
Show/hide whole right panelCtr+L
Toggle Full ScreenF11
VFB SettingsS
History/Render ViewEnable history A/B/C/D compare modeE
Enable history A/B horizontal compare modeQ
Enable history A/B vertical compare modeW
Load the respective image from the VFB history (1...9)
1; 2; 3; 4; 5; 6; 7; 8; 9
Layers/Property PanelRedoCtr+Y
UndoCtr+Z
LayersDelete a layerDel
Message LogClose SearchEsc
Find in LogCtr+F
Find nextReturn
Find previousShift+Return
Render View Abort renderingEsc
Copy current channel to clipboardCtr+C
Flip horizontallyM
Flip verticallyShift+M
Load imageCtr+O
Lock pixel info coordinatesL
Pan image (up, left, down, right)Up; Left; Down; Right (arrow keys)
Switch to Alpha channelA
View blue channelB
View green channelG
View next channelPgDown
View previous channelPgUp
View red channelR
Zoom 100%* ; Double-click left button
Zoom in+ / =
Zoom out-/_
Zoom to fitF
Zoom in the rendered imageCtrl+Shift+Left click
Zoom out the rendered imageCtrl+Shift+Right click
Symmetric render region resizingAlt+resize
UI Text Box
typeinfo
Note that the keyboard shortcuts work only within the VFB window.
UI Text Box
typetip
The shortcut keys can be modified in the VFB's options from VFB > Options > Shortcuts tab > Edit hotkeys.
Render Region
Region rendering is available in both IPR and Production modes. It allows the isolation of parts from the whole frame for rendering.
Image Added
Region renderRenders rectangular regions in the VFB.
Image Added
Polygon region renderRenders multiple polygonal regions in the VFB.
 A right-click context menu is available for the Polygon region render:
width55%
Freeform – Selects the Polygon region render mode.
Rectangular – Selects the Region render mode.
Add/Delete vertex – Adds/deletes vertices of a selected polygon.
Delete polygon – Deletes the selected region.
Delete all – Deletes all regions.
Undo/Redo – Undoes/redoes various actions related to the region render shapes.
UI Text Box
typenote
The context menu is only available when the Polygon region render is selected. Right-click in the VFB viewport to open.
width5%
width40%
Image Added
Saving Files With Render Region
width40%
width20%
Image Removed
width40%
Command
Description
Stats
UI Text Box
typetip
width20%
width60%
Image Removed
width20%
Log
The Log panel provides messages about the render process. Verbosity control is available and you can filter the type of messages shown in the Log: AllError OnlyError & Warnings, or Error, Warnings & info. Additional options are available when you click on the Open options Image Removed button:
UI Text Box
typetip
width35%
width30%
Image Removed
width35%
VFB Shortcuts
UI Text Box
typeinfo
UI Text Box
typetip
Render Region
Region rendering can be used in both IPR and Production modes to isolate only part of the frame for rendering. Usually, when a render region is used, you would like to save the whole frame instead of the region only.
