Progress Bar Container
step3
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Houdini
urlV-Ray Configuration
Loading the V-Ray Shelf
width50%
When starting V-Ray for Houdini for the first time, you need to manually load the V-Ray Shelf. From the Houdini shelf, click the plus + icon, navigate to Shelves, and select V-Ray from the list.
width5%
width45%
Image Modified
Anchor
rendererSelection
rendererSelection
Selecting a Renderer
width50%
To render with V-Ray, simply click the Render button from the V-Ray Shelf. This automatically creates a vray_renderer node in the Network Editor (if one is not already present) and launches the V-Ray Frame Buffer.
width5%
width45%
Image Modified
width50%
If a ZIP or silent installation is used without accepting the End User License Agreement and the Global Consumer Privacy Policy, you are prompt to accept them when initiating a render in order to use V-Ray.
Enable the I Accept checkboxes and click Accept in order to proceed using the software.
width5%
width45%
Image Added
