width20%
width60%
width20%
Chaos Telemetry Settings
You can change the telemetry settings The Chaos Telemetry settings can be changed directly in 3ds Max at any time after installing Corona. To access the settings, make sure Corona is set as the current renderer and go to the Corona System SettingsSetting window through the from Render Setup window > System Tab > System Settings . Make sure Corona is set as the current renderer.Enabling the Send Product usage data (takes effect after 3ds Max restart) option launches the Chaos Improvement Program for Coronabutton. Clicking the Settings button under Product Usage Data launches the Chaos Telemetry settings window. For more details, refer to the System Tab page.
width5%
width40%
Image Added
Corona System Setting window
width10%20%
width40%60%
Image AddedImage Removed
Chaos Telemetry window
20%
width5%
Alternatively, Chaos Telemetry settings can be changed at any time by re-installing Corona for 3ds Max and changing your choice at the end screen of the installer.
