  • Automatic License Engagement: After signing in, Enscape will now attempt to automatically engage a license if available, reducing the need to reopen windows or restart workflows.
  • Trial Watermark Display: Trial users will continue to see a watermark indicating they’re on a trial versionA small watermark has been reintroduced in the corner of renderings for trial users.
Fixed Bugs
  • Improved batch render performance in SketchUp to avoid crashes and reduce render times, matching performance levels seen in other CADs.
  • Resolved a crash when closing Enscape while it was trying to connect to an invalid license server.
  • Fixed a problem where the migration popup blocked the sign-out confirmation window, ensuring smoother account management.
  • Fixed an issue where Enscape buttons in the Revit toolbar were grayed out when projects were opened via double-click instead of via the Revit Manager.
  • Resolved freezing during VRScene export when working with section planes in SketchUp.
  • On machines without prior Enscape installation, the Custom Asset Editor fails to open when accessed standalone or via the "+" icon in the Custom Asset Tab.
  • Fixed an issue where Enscape appeared as a separate taskbar icon when used with Vectorworks 2024 2.1.
