Comment: added channel type
HideElements
cssselector#tocHorizontal, #tocVertical
This page provides information about the Material ID Render Channel in V-Ray for Blender.
width50%
The Material ID Render Channel isolates objects with specific materials by Material ID for compositing purposes. This render channel provides a mask for individual objects and materials that is easy to select in compositing software.
This render channel either shows each material (by Material ID) as a solid unshaded color or stores the Material IDs as integer values within the EXR format or VRay Image Format file.
The Color (with Anti-Aliasing) method supports antialiasing at the edges of objects where they meet other objects or the background. The Integer (no Anti-Aliasing) method, which assigns a Material ID to each pixel in the render channel, does not support antialiasing as each pixel can have only a single Material ID assigned to it.
More than one Material ID render channel can be used if desired, for example, if you wish to have both solid-shaded color and integer-based render channels for maximum flexibility during compositing.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Matte > V-Ray Material ID
width5%
width45%
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAftermaterial id channel
height80%
Properties
width50%
Enable Deep Output Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
width5%
width45%
Image Added
