Comment: added channel type
This page provides information about the Object ID Render Channel in V-Ray for Blender.
HideElements
cssselector#tocHorizontal, #tocVertical
width50%
Two or more objects in the scene can share the same Object ID.
The Object ID Render Chanel creates selection masks based on Object ID that
shows
show each object (by Object ID) in a solid unshaded color.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Matte > V-Ray Object ID
width5%
width45%
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAfterstool selected
height80%
Properties
width50%
Enable Deep Output – Includes this render element in deep images.
width5%
width45%
Image Added
