Comment: added channel type
This page provides information about the Raw Coat Filter Render Channel in V-Ray for Blender.
HideElements
cssselector#tocHorizontal, #tocVertical
width50%
The Raw Coat Filter Render Channel is similar to the Coat Filter Render Channel, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection calculated from the V-Ray Mtl Coat Layer.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Raw > V-Ray Raw Coat Filter
width5%
width45%
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAfterraw coat filter
height80%
Properties
width50%
Enable Deep Output Specifies whether to include this render channel in deep images.
Color Mapping  Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
width5%
width45%
Image Added
