Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVSKETCHUP:Swarm Settings
V-Ray Swarm for SketchUp
See how to operate V-Ray Swarm within V-Ray for SketchUp.
Textboxcard
CardPageLinkVRHINO:Swarm Settings
V-Ray Swarm for Rhino
See how to operate V-Ray Swarm within V-Ray for Rhino.
Textboxcard
CardPageLinkVREVIT:Operating Swarm in Revit
V-Ray Swarm for Revit
See how to operate V-Ray Swarm within V-Ray for Revit.
Features Features
Multiexcerpt
MultiExcerptNameswarmOverview2
All that is needed to dedicate a machine as a V-Ray Distributed Rendering server, is to install and run V-Ray Swarm on it. V-Ray Swarm discovers and adds machines for rendering, handles the installation of V-Ray Standalone builds on each machine, starts and stops the rendering process, monitors CPU, RAM, and GPU resources per system, and deploys the configuration of V-Ray on all V-Ray Swarm machines with a single click. V-Ray Swarm makes V-Ray Distributed Rendering easier than ever.
The new features that V-Ray Swarm adds to V-Ray Distributed Rendering are:
Fancy Bullets
typecircle
  • Ensures every machine is rendering with the same version of V-Ray.
  • Provides the ability to monitor and manage the entire V-Ray Swarm network through a web interface. The percentage of computing power currently being used can be manually and interactively adjusted.
  • Monitors the state of each computer to make sure that V-Ray is active and ready, and restarts V-Ray if necessary.
  • Automatically discovers machines running V-Ray Swarm over the network, eliminating the need to manually input the IP address/hostname of each render server machine.
  • Automatically or manually assigns a computer to be the one that controls and manages V-Ray Swarm on the render node machines.
UI Text Box
typenote
V-Ray Swarm controls V-Ray Distributed Rendering on each render node machine; the actual rendering is handled by V-Ray Standalone.
UI Text Box
typenote
Each machine participating in the render job requires a V-Ray Render Node license. This includes the workstation initiating the rendering process.
V-Ray Swarm does not provide licenses. Instead, each render node must be connected to a Chaos License Server.
