The Current View Quick Settings, found in the Chaos Envision viewport, allow you to switch between different camera views, scene variations, and environment setups. These settings are handy when you're working with the timeline and want to do quick changes without moving the play head from its current position and or having to navigate through the timeline.
width
5%
width
35%
width
60%
Indicator
Description
Variation
Allows you to switch between scene variations. All scene variations are listed in the Variations tab > Scene subtab in the left-hand side panel.
Environment
Allows you to switch between environment variations. All environment variations are listed in the VariationsEnvironmenttab > Environment subtab in the left-hand side panel.
Camera
Switches to Perspective View.
Switches to Top View.
Switches to Bottom View.
Switches to Right View.
Switches to Left View.
Switches to Front View.
Switches to Back View.
Switches to Camera view. All available camera views are listed in the Cameras tab in the left-hand side panel. You can create more camera views from the tab.
