The Objects tab provides searchable lists, i.e. filter tabs, of all objects in the scene, grouped by type: geometry, scatter, spline, light, camera, and Cosmos assets. When an object is selected, its parameters are displayed in the Details tab in the right-hand side panel.
A tab for all types of objects in the project.
A filter tab for all meshes in the project.
A filter tab for all scatter objects in the project.
A filter tab for all spline objects in the project.
A filter tab for all lights in the project.
A filter tab for all cameras in the project.
A filter tab for all Cosmos assets in the project
width
5%
width
35%
Options
Actions with Objects
width
60%
Search objects – Searches for a specific object or objectsusing the Search field. It filters the objects and shows only those objects that contain the input string from match the search. Click the X button on the right to clear the input stringsearch.
Expand/Collapse all – Expands or collapse collapses objects that are in a hierarchy (parents and children).
Filter by scene – Filters the objects list by scene when multiple scenes are imported.
Lock – Disables the object objects transformation options - position, rotation and scale. The options become greyed out. ClickImage Modifiedto unlock enable the options for manipulation again.
Toggle Hide – Toggles the visibility of the element on and off. Invisible objects are indicated by and are not rendered. When a parent element is invisible in a hierarchy, the child object is indicated by a dot and also inherits the invisibility.
Groupand ungroup objects by the right/ungroup nodes – Right-click menu options that group and ungroup objects. The folder icon is an indicator for grouped objects. See the Menu Options section for more details.
Place Drag-and-drop – Places objects in hierarchy.
