width55%
Count – Defines an exact number of instances to scatter - either overall, or per area in the case of scattering defined by density (Per Square option). The number is always limited by the Instance Count Limit option. See the Count example below for more information.
Per Square – When enabled, the number of instances to scatter is defined by density (Count per square having the given edge length). The number of instances is always limited by the Instance Count Limit option. See the Per Square example below for more information.
Square Size – The specified value is the edge length of a square defining an area for computing the scatter density. The length is measured in world units.
Density Texture 1 – Allows a black-and-white texture map to be assigned. The map determines how the instances are scattered on the surface. User attributes can also be assigned to determine the scattering.
width5%
width40%
width5%
width45%
Image slider
startIndex1
Panel
borderStylenone
01_UVGrid_PatternGrid_Offset_U0_V0
Offset = U 0; V 0
Panel
borderStylenone
03_UVGrid_PatternGrid_Offset_U0_V0x5
Offset = U 0; V 0.5
Panel
borderStylenone
Offset = U 0; V 0.75
Panel
borderStylenone
05_UVGrid_PatternGrid_Offset_U0_V1
Offset = U 0; V 1
width45%
Image slider
startIndex2
Panel
borderStylenone
Offset = U 0; V 0
Panel
borderStylenone
02_UVGrid_PatternGrid_Offset_U0x25_V0x25
Offset = U 0.25; V 0.25
Panel
borderStylenone
03_UVGrid_PatternGrid_Offset_U0x5_V0x5
Offset = U 0.5; V 0.5
Panel
borderStylenone
04_UVGrid_PatternGrid_Offset_U0x75_V0x75
Offset = U 0.75; V 0.75
Panel
borderStylenone
05_UVGrid_PatternGrid_Offset_U1_V1
Offset = U 1; V 1
width5%
Fancy Bullets
typecircle
  • Density Texture and maps added to Translation, Rotation, and Size are not represented in the viewport. For more information on texture interpolation, see the Texture Filter section.
Progress Bar Container
step3
Progress Bar - Hyperlink Step
titleOverview
urlChaos Scatter
titleCurve Scattering
urlCurve Scattering
titleSurface Scattering
urlSurface Scattering
titleAdvanced Surface Scattering
urlAdvanced Surface Scattering
titleBounding Box Scattering
urlBounding Box Scattering
titleAdvanced Scatter Features
urlAdvanced Scatter Features
