This article explains the settings and values for the Scatter Edge Trimming shader in Cinema 4D.
width50%
The Scatter Edge Trimming shader allows you to trim scattered instances consisting of multiple mesh elements so that they stay within the boundaries of the distribute-on objects or the include/exclude splines. In addition to making the scattering look more refined and natural, this feature also provides a performance increase - thanks to removing some of the instances, you can save RAM and make parsing time shorter.
To learn more, see also:
UI Text Box
typetip
Alternatively, you can use the Edge Trimming feature instead. When enabling the Edge trimming feature, there's no need to use the Edge Trimming Shader
width5%
width45%
Shader properties
width50%
Default shader –  If a material is using some opacity texture in addition to the Scatter Edge Trimming shader, this texture can be defined here.
UI Expand
titleUI Path: || Node Material Editor || > Create > New shader > Corona > Scatter Edge Trimming
UI Text Box
typenote
Note: If V-Ray is also installed on the computer, the UI Path will be as follow: UI Path: || Node Material Editor || > Create > New shader > plugins > Scatter Edge Trimming
UI Text Box
typetip
Using the right-click on the working area can also show the menu to create new shaders/materials.
width5%
width45%
Example
width20%
width60%
Before after
afterLabelWithout Scatter Edge Trimming
beforeLabelWith Scatter Edge Trimming
Panel
Panel
UI Expand
titleClick here to see the material setup
width20%
