Comment: Reverted from v. 2
width20%
width60%
width20%
Chaos Telemetry Settings
The Chaos Telemetry settings can be changed You can change the telemetry settings directly in 3ds Max at any time after installing Corona. To access the settings, make sure Corona is set as the current renderer and go to the Corona System SettingSettings window from through the Render Setup window > System Tab > System Settings button. Clicking the Settings button under Product Usage Data launches the Chaos Telemetry settings window. Make sure Corona is set as the current renderer.
Enabling the Send Product usage data (takes effect after 3ds Max restart) option launches the Chaos Improvement Program for Corona. For more details, refer to the System Tab page.
width5%20%
width40%60%
Image Added
Image Removed
Corona System Setting window
width10%
width40%
Image Removed
Chaos Telemetry window
width5%
20%
