width55%
The Details tab is a context-based right-hand side panel tab based tab that displays the settings of the currently selected scene element. The scene element can be selected from other tabs, such as Cameras, Objects, or Lights, or directly in the viewport.The  The content of the Details tab automatically updates based on the selected element, allowing you to easily adjust the element's settings.
The Details tab is located in the right-hand side panel.
width5%
width40%
width55%
The following parameters are available when multiple elements are selected.
A field showing how many elements are selected.
Lock –Disables – Disables the elements transformation options - position, rotation and scale. The options become greyed out. Click to enable the options for manipulation again.
Hide – Toggles the visibility of the elements on and off. Invisible elements are indicated by and are not rendered.
Move pivot – Opens the Pivot Point Adjustment settings. There you can move adjust the pivot point of the selection.
Select hierarchy All – Selects the parent element and all of its childrenchildren of the current selection from within the scene hierarchy.
Select hierarchy Parent only – Selects only the parent elementof the current selection from within the scene hierarchy.
Select hierarchy All children – Selects all children elements. the rest of the children in the scene hierarchy group the current selection belongs to.
Make instance unique – Excludes the selection from the rest of its instances and makes it unique. The action is disabled if the selection has no instances.
Select all instances –Selects – Selects all instances the selected objects have in the scene.
Align objects – Opens the Align Objects settings. There you can align the selected objects along the X, Y, and Z axes.
Distribute objects – Opens the Distribute Objects settings. There you can distribute the selected objects at equal spacing along a selected X, Y, and Z axisaxes
Transformation
Position – Moves the selected elements along the X, Y and Z axes.
Rotation – Rotates the selected elements along the X, Y and Z axes.
Scale – Scales the selected eliminants along the X, Y and Z axes.
width5%
width40%
Align Objects
width55%
Aligns the selected objects to a shared, virtual pivot point, which can be positioned at the base, middle, or top of the objects.
Off –
Maximum –
Middle –
Minimum –
Use –
Extents –
Pivot –
width5%
width40%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
CardPageLinkCosmos Tab
Cosmos Assets Details
Detailed information about Chaos Cosmos assets parameters.
Textboxcard
CardPageLinkAnima Crowd Details
Anima Crowds Details
Detailed information about Anima Crowds parameters.
Textboxcard
CardPageLinkCamera Details
Camera Details
Detailed information about camera parameters.
Textboxcard
CardPageLinkLight Details
Lights Details
Detailed information about lights parameters.
Textboxcard
CardPageLinkMaterial Editor
Material Editor
Detailed information about materials preview.
Textboxcard
CardPageLinkStandard Material
Material
Materials
Details
Detailed information about materials parameters.
Textboxcard
CardPageLinkTextures
Texture Details
Detailed information about texture parameters.
Textboxcard
CardPageLinkObject Details
Objects Details
Detailed information about objects parameters.
Textboxcard
CardPageLinkScatter
Scatter Details
Detailed information about Chaos Scatter parameters.
Textboxcard
CardPageLinkSpline Details
Spline Details
Detailed information about spline parameters.
