The Filter/Layer presets tab holds the settings controlling the Filters and Layers tabs.
Path– Shows the path that holds the layer tree and filter presets.
Browse– Opens a browser to pick the Filter/Layer presets folder.
Recent– Shows a list of recently used locations for loading layer tree and filter presets.
Use own image Layer stacks when comparing in History– When enabled, the Layer panel is disabled and HistoryA/B/C/D Compareuses the respectiveLayerssetup of each image.When comparing the current render to one from the History panel, editing the Layers setup is available and is applied only to the current render. When comparing images from the History panel, the Layers panel is disabled and editing the Layers tree is not possible.
Ignore existing correction for the Filter thumbnails– When enabled, each Filter thumbnail previews the preset applied to the original image ignoring other correction layers present in the layers stack. When disabled, the complete layers stack is taken into account.
width
5%
width
35%
Image RemovedImage Added
Shortcuts
width
60%
The Shortcuts tab displays a table, containing all Shortcuts for navigating through the VFB image as well as controlling the panels of the new VFB.
Please note that the VFB window must have the current focus for the shortcuts to take effect.
