Section | ||||||||||||||||||
Configuration File
The config.xml file holds configuration information about the settings of the installation. Below is an example of a config file content.
Code Block |
<DefValues> <Value Name="SHOULDUNINSTALLADDINS25" DataType="value">1<>C:\ProgramData\Autodesk\Revit\Addins\2025</Value> <Value Name="REVITINSTALL_EXECONTENT_ROOT20BROWSER" DataType="value">NOTINSTALLED<>1</Value> <Value Name="REVIT_EXE_ROOT21ROOT23" DataType="value">C:\Program Files\Autodesk\Revit 2021\<>NOTINSTALLED</Value> <Value Name="REVIT_EXE_ROOT22APPDATA23" DataType="value">C:\Program Files\Autodesk\Revit 2022\<Users\<username>\AppData\Roaming\Chaos\V-Ray for Revit 2023</Value> <Value Name="LICINSTALL_TYPEREVIT24" DataType="value">adv<>1</Value> <Value Name="PREVIOUS_REVITROOTAPPDATA25" DataType="value">C:\ProgramData<\Users\<username>\AppData\Roaming\Chaos\V-Ray for Revit 2025</Value> <Value Name="REVERT_INSTALL" DataType="value">1</Value> <Value Name="PROGRAMFILESADDINS23" DataType="value">C:\Program Files<\ProgramData\Autodesk\Revit\Addins\2023</Value> <Value Name="SWARM_ENABLED" DataType="value">0</Value> <Value Name="REVITROOTINSTALL_REVIT25" DataType="value">C:\ProgramData<>0</Value> <Value Name="STDROOTSTDROOTOLDCGVR" DataType="value">C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit<Ray</Value> <Value Name="ADDINS20REVIT_EXE_ROOT25" DataType="value">C:\ProgramData\Autodesk\Revit\Addins\2020<>NOTINSTALLED</Value> <Value Name="ADDINS21REVIT_EXE_ROOT24" DataType="value">C:\ProgramDataProgram Files\Autodesk\Revit 2024\Addins\2021<</Value> <Value Name="ADDINS22ADDINS24" DataType="value">C:\ProgramData\Autodesk\Revit\Addins\2022<2024</Value> <Value Name="DATAFILESAPPDATA24" DataType="value">C:\ProgramData\VRay4Revit<\Users\<username>\AppData\Roaming\Chaos\V-Ray for Revit 2024</Value> <Value Name="STARTMENUPROGINSTALL_REVIT22" DataType="value">C:\ProgramData\Microsoft\Windows\Start Menu\Programs<>0</Value> <Value Name="INSTALL_REVITSWARM" DataType="value">1<>0</Value> <Value Name="INSTALLSWARM_REVIT20DONOTUSELOCALMACHINE" DataType="value">0</Value> <Value Name="INSTALLREVIT_EXE_REVIT21ROOT22" DataType="value">0<>NOTINSTALLED</Value> <Value Name="INSTALLPREVIOUS_REVIT22REVITROOT" DataType="value">1<>C:\ProgramData</Value> <Value Name="INSTALLCONFIGURE_LICENSE_SWARMONLY" DataType="value">1<>0</Value> <Value Name="INSTALLREMOTE_LICENSE_SERVER" DataType="value">1<>0</Value> <Value Name="OPEN_CHANGELOGDATAFILES" DataType="value">1<>C:\ProgramData\VRay4Revit</Value> <Value Name="REMOTE_LICENSEAPPDATA22" DataType="value">0<>C:\Users\<username>\AppData\Roaming\Chaos\V-Ray for Revit 2022</Value> <Value Name="REGINSTALL_LICLICENSE_SERVER" DataType="value">1<>0</Value> <Value Name="FIREWALLLOCAL_APPDATA_EXCEPTIONPATH" DataType="value">1<>C:\Users\<username>\AppData\Local\Chaos\V-Ray for Revit</Value> <Value Name="TEMPDIRADDINS22" DataType="value">C:\ProgramData\UsersAutodesk\<username>Revit\AppData\Local\Temp<Addins\2022</Value> <Value Name="REVITROOT" DataType="value">C:\ProgramData</Value> <Value Name="INSTALL_REVIT23" DataType="value">0</Value> <LicServer> <Host>127.0.0.1</Host> <Port>30304</Port> <Host1>localhost<<Host1></Host1> <Port1>30304</Port1> <Host2></Host2> <Port2>30304</Port2> <User></User> </LicServer> </DefValues> |
Below is a description of the variables of the installer:
SHOULDUNINSTALL | Specifies the uninstall type: 0 - Does not uninstall previous installation. 1 - Uninstall previous installation. | |||||||||
STDROOT | Specifies the root Revit folder. The default is C:\Program Files\Chaos | Group\V-Ray\V-Ray for Revit | ||||||||
MATERIALS_LIBRARY | Specifies location for the V-Ray material library (the library itself should be downloaded from within the gui after a successful installation). The default location is C:\Users\<username>\Documents\ | V-Ray Material LibraryChaos Cosmos\Packages\Materials | ||||||||
REVERT_INSTALL | The parameter is used when the installer encounters an error – it triggers uninstallation and removes the files that have been populated before the error appears. Should always be set to its default 1. | |||||||||
INSTALL_REVIT | Specifies the installation type: 0 - Does not install V-Ray for Revit. This is useful when you want to install only V-Ray Swarm, for example. 1 - Installs V-Ray for Revit. | |||||||||
INSTALL_REVIT19 | INSTALL_REVIT20 | Specifies the installation of V-Ray for Revit 2020: 0 - Does not install V-Ray for Revit 2020. 1 - Installs V-Ray for Revit. | INSTALL_REVIT21 | Specifies the installation of V-Ray for Revit 2021: 0 - Does not install V-Ray for Revit 2021. 1 - Installs V-Ray for Revit. | INSTALL_REVIT22 | Specifies the installation of V-Ray for Revit 2022: 0 - Does not install V-Ray for Revit 2022. 1 - Installs V-Ray for Revit. | INSTALL_REVIT23INSTALL_REVIT23 INSTALL_REVIT24 INSTALL_REVIT25 | Specifies the installation of V-Ray for Revit | 20232019 - 2025: 0 - Does not install V-Ray for Revit | 20232019 - 2025. 1 - Installs V-Ray for Revit. |
REVITROOT | Specifies the root Revit folder. The default folder is C:\ProgramData | |||||||||
REVIT_EXE_ROOT19 | Specifies the folder location for the Revit 2019 .EXE file. The default is C:\Program Files\Autodesk\Revit 2019 | |||||||||
REVIT_EXE_ROOT20 | Specifies the folder location for the Revit 2020 .EXE file. The default is C:\Program Files\Autodesk\Revit 2020 | |||||||||
REVIT_EXE_ROOT21 | Specifies the folder location for the Revit 2021 .EXE file. The default is C:\Program Files\Autodesk\Revit 2021 | |||||||||
REVIT_EXE_ROOT22 | Specifies the folder location for the Revit 2022 .EXE file. The default is C:\Program Files\Autodesk\Revit 2022 | |||||||||
REVIT_EXE_ROOT23 | Specifies the folder location for the Revit 2023 .EXE file. The default is C:\Program Files\Autodesk\Revit 2023 | |||||||||
ADDINS19 | Specifies the addins folder for Revit 2019. The default is C:\ProgramData\Autodesk\Revit\Addins\2019 | |||||||||
ADDINS20 | Specifies the addins folder for Revit 2020. The default is C:\ProgramData\Autodesk\Revit\Addins\2020 | |||||||||
ADDINS21 | Specifies the addins folder for Revit 2021. The default is C:\ProgramData\Autodesk\Revit\Addins\2021 | |||||||||
ADDINS22 | Specifies the addins folder for Revit 2022. The default is C:\ProgramData\Autodesk\Revit\Addins\2022 | |||||||||
ADDINS23 | Specifies the addins folder for Revit 2023. The default is C:\ProgramData\Autodesk\Revit\Addins\2023 | |||||||||
INSTALL_SWARM | Specifies whether or not to install V-Ray Swarm: 0 - Does not install Swarm. 1 - Installs Swarm. | |||||||||
SWARM_ENABLED | Specifies whether or not to enable V-Ray Swarm during installation: 0 - Does not enable Swarm. 1 - Enables Swarm. | |||||||||
SWARM_GOAL | Allows you to set in advance the desired percentage of utilization of available resources. Computers added to or removed from V-Ray Swarm are taken into account automatically. The default is 60. | |||||||||
SWARM_DONOTUSELOCALMACHINE | Specifies whether to exclude the local machine from rendering: 0 - The local machine is used. 1 - The local machine is not used. However, V-Ray Swarm proceeds using a small percentage of the local machine's resources to communicate with the nodes. | |||||||||
AUTO_DISCOVERY | Specifies whether the installation should search for other nodes in the network: 0 - Does not search for other nodes in the network. 1 - Enables auto discovery and the installation searches for other nodes in the network. | |||||||||
DISCOVERY_MASTER | Specifies the Coordinator's IP address. | |||||||||
SWARM_TAGS | Tags this node with a descriptor that defies something about the machine, which can later be used to selectively control from inside of Revit. Tags must be separated with a comma. | |||||||||
INSTALL_LICENSE_SERVER | Specifies whether or not to install the V-Ray license server: 0 - Does not install the V-Ray license server. 1 - Install the V-Ray license server. | |||||||||
OPEN_CHANGELOG | Specifies whether or not to open the Change Log once the installation is complete: 0 - Does not open the Change Log. 1 - Opens the Change Log. | |||||||||
REMOTE_LICENSE | Specifies whether the V-Ray license server runs locally or on another machine: 0 - The license server runs locally on the same machine. 1 - The server is on a different machine in the network. | |||||||||
LIC_TYPE | Specifies the type of license. | |||||||||
FIREWALL_EXCEPTION | Specifies whether to add a Firewall Exception for the V-Ray license server: 0 - Does not add a Firewall Exception for the V-Ray license server. 1 - Adds a Firewall Exception for the V-Ray license server. | |||||||||
TELEMETRY | Specifies whether anonymous usage statistics is enabled or disabled. |
Fancy Bullets | ||
