HideElements | ||
The V-Ray installer automatically uninstalls any previous versions. Uninstalling V-Ray from Revit does not uninstall Chaos Cloud Client, Chaos Cosmos Browser, Chaos License Server, Chaos Unified Login and V-Ray Swarm. Those can be uninstalled separately if needed.
Uninstall
If you need to manually uninstall V-Ray, make sure that Revit or V-Ray components are not being used.
Then open the Windows Start Menu > All apps > Chaos Group > Uninstall V-Ray for Revit or or alternatively run C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit\uninstall\Uninstall.lnk.
UI Text Box | ||
For versions prior to V-Ray 7, the default location of the Uninstall.Ink file is C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit\uninstall. |
This starts the V-Ray uninstaller. Follow the on-screen instructions to remove V-Ray from your system and restore any files overwritten by the installation.
