UI Paths
Section | ||||||||||||||||||||||||||||
Workflow
- Create a geometry in the Asset Editor from the Geometry drop-down menu or from Create Asset > Geometries. Currently, the geometry is not assigned to any object in the scene and it is not visible during render.
- In the Appearance Manager, navigate to the material/object that should have a geometry assigned to it.
UI Text Box | ||
You can also drag-and-drop a V-Ray asset onto an asset in the Appearance manager panel. |
Virtual Geometry
V-Ray provides a number of tools that create geometry loaded only at render time, that does not weigh to the project.
Responsivegridmacro | ||||||||||||||||
Div | ||||||||||||||||||||||||||||||||||||||||||
