Progress Bar Container | |||||||||||||||||
MultiExcerptName | License Start
Multiexcerpt | |||||||||||||||||
Activate the License
Chaos
Licensing is the bridge between the Chaos Product (Anima) and the Chaos Account associated with a given license. You cannot use any Chaos product without a license.
You connect to the License Server by installing the license application locally on your machine or
Please follow the instructions for your subscription plan:
borderColor | darkgrey |
titleColor | white |
titleBGColor | darkgrey |
borderStyle | solid |
title | Solo License |
The Solo License requires the server to be installed directly on your machine. The Solo License can only be used by a single user with a user login.
type | circle |
by a using a (remote connection to) floating license from a shared pool of licenses.
Local Chaos License Server on This Machine
After the installation is complete, you
are redirected to the Chaos License Server's Interface. If you are not signed into a Chaos account, go to the Online licensing dropdown menu and select Sign in.
type | circle |
You are then prompted to enter your username/email and password.
Once the activation is successful, you
are able to see the list of your available licenses on the Chaos License Server home page.
UI Text Box | ||||||||||
If you accidentally close the window, you can type 127.0.0.1:30304 / localhost:30304 in a web browser. Keep in mind that you cannot use any Chaos products without an active license! Panel | | |||||||||
Remote Chaos License Server on the Network
If you have multiple Anima licenses, they can be shared between multiple users and devices
When doing a shared setup for a Premium license, the license holder needs to install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license. If you are the license holder, i.e., the administrator, see the Administrator Workflow page.
Here is how to connect to an already set-up Premium shared license:
Fancy Bullets | ||
width | 25% |
width | 50% |
Example screenshot
width | 25% |
Fancy Bullets | ||
Borrow Licenses for Offline Use
in one of two ways.
- The easiest way to do so is to use My Chaos Portal options and enable Floating licensing sharing. See how in the Cloud-Based Floating Licensing article or video included.
OR
2. Alternatively, you can set up a local network by installing the license server on one machine and sharing its IP address to the rest of the users in the network. For further details on how to do it, see the Administrator Workflow article.
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
Panel | ||||
Visit the License ServerChaos Licensing section of the documentation for further details on the Chaos License Server, such as how to check your license expiration and status, how to access various settings, and more advanced options. |
Next Step
Go to step 3 to see how to load Anima.
