Envision 0.
4.0
Beta Release, Update 34
Date - February 26March 27, 2025
UI Button
colorblue
titleSign up for Chaos Envision Beta
urlhttps://www.chaos.com/envision#join
UI Button
colorblue
newWindowtrue
titleDownload Chaos Envision Beta
urlhttps://download.chaos.com/?platform=47&product=77
Improvements
  • Added ability to automatically detect and render the Environment parameters coming from the .vrscene file.
  • Source path customization for opened/linked referenced scenes.
  • Moved Embed functionality from File->Import menu to linked scene's details setting.
Crash Fixes
  • Random crashes in unit scaler when loading large scene.
Envision 0.3.0
Date - February 26, 2025
New Features
  • Add support for Sketchup UVW scale attribute during import.
Improvements
  • Updated the timeline play-head design.
  • Color Corrections: when the type is set to Ampas, non applicable parameters are hidden.
  • Color Corrections: highlight burn is disabled when Filmic tone-map is on as it is not applicable in that case.
  • Disabled Seams blend of textures when Make Seamless is disabled.
Crash Fixes
  • Failure to detect dedicated GPU leads to crash and Lavina renderer issues.
  • GPU device instance suspension, system ran out of resources leads to crash.
  • Crash when trying to render a simple scene.
  • Crash after texture assignment on enhancements and tweaking of properties (regression).
  • Material foliage no longer works (regression).
  • Assert - Stack.h Line: 526, application close during asset download (conditional).
  • Cannot render still image while animation is running.
  • Fix issue with drag and drop actor in crowd list.
  • Proxy(GeomMeshFile) scale is not imported correctly.
  • Invalid mpeg output with specific aspect ratios.
  • Bind character to spline path leads to wrong transforms.
  • Scatter still visible when hidden.
  • Can not pick dummy as look at target.
  • SVG icons are pixelated on systems with DPI scaling.
Crash Fixes
  • Prevent out of memory issues when exporting video with resolution above 7680(8k).
  • Failure to detect dedicated GPU leads to crash and renderer issues.
