2. Alternatively, you can set up a local network by installing the license server on one machine and sharing its IP address to the rest of the users in the network. For further details on how to do it, see the Administrator Workflow article.
Change Chaos Anima License Settings
width55%
You can change the Anima's license settings, which specify the location of the license server. To do that, run the Chaos license client configuration utility from Windows Start > Chaos Anima 6 > Change license settings.
width5%
width40%
Image Added
width55%
The Chaos license settings window appears, where you can specify the IP address of the machine running the License Server.
For example, if the license server machine has an IP address of 10.0.0.100, you have to put that address in the License server field under the Primary license server tab.
UI Text Box
colorlight-red
iconwarning
The Alternate License Server options do not work with Chaos Anima, yet.
width5%
width40%
Image Added
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
