Comment: links on top of page updated
Panel
borderColor#42BEFF
borderStylesolid
width40%22%
 Download  Join the V-Ray for Blender 4.2/4.3 Beta Community
UI Button
colorblue
newWindowtrue
icondownloadnotification
titleGet Join the V-Ray for Blender Beta
urlhttps://try.chaos.com/beta/blender
width5%
Div
styledisplay: table-cell; border-left: 1px solid; color: #42BEFF;
width5%
width47%35%
Take the Blender Setup survey, so we can improve your V-Ray for Blender experience.
UI Button
colorblue
newWindowtrue
iconedit
titleTake the survey
urlhttps://chaos.surveysparrow.com/s/v-ray-for-blender---beta/tt-DsNrd
width5%
Div
width5%
width23%
Download V-Ray for Blender Beta
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for Blender
urlhttps://my.chaos.com/download/build?product=V-Ray&platform=Blender&platform-version=4.3&build-type=beta&tags=windows-x64
Running the Installer
UI Steps
UI Step
width60%
Welcome
Once you've carefully read the License Agreement and the Privacy Policy, check the boxes next to them, if you agree to the terms.
Proceed to click the Install button and wait for V-Ray to complete the process.
width5%
width35%
UI Step
width60%
V-Ray installation is successful.
Participate in the improvement decisions for future versions of V-Ray. When agreeing to participate in the feedback program, no intelligence property is violated. Chaos does not gather scenes, assets, materials, etc. This preference can be changed anytime from within the interface. For more information, see the Chaos Telemetry page.
Anonymized Telemetry – Includes the most used product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
Personalized Telemetry – Includes the most used product functionality and parameter values but also contains personally identifiable information tied to an individual user's license. This helps Chaos tailor and optimize the product for better personal use.
width5%
width35%
UI Steps
UI Step
width60%
Directories
Here, you can specify the installation paths. Please check if the default folders are correct.
Add firewall exceptions – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you will need to manually add firewall exceptions later.
width5%
width35%
UI Step
width60%
Licensing
In this step, specify whether the Chaos License Server runs locally or on another machine.
If you select Remote licensing, you have to enter the IP address of your Chaos License Server in the Primary License Server field. Leave port 30304 unchanged. An Alternate License Server can be used for redundancy in case the primary one does not respond. The License Server will not install when the Remote option is selected. When Local licensing is selected, the Chaos License Server is installed with V-Ray.
width5%
width35%
UI Step
width60%
At this step, you can choose where to install the Chaos License Server.
Migrate data during installation – When enabled, it transfers all of your settings made with older versions of the License Server, such as proxy settings, etc. Disabling this option makes a clean install of License Server with any custom settings from previous installations reset to their defaults.
Add firewall exception – Allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you must manually add firewall exceptions later.
width5%
width35%
