Comment: display color property
MoGraph AttributesCinema 4D Attributes
Color – The color value of the Cloner object. Object Color – The default color of the object. This color can be changed from the project settings.
Color sRGB – the color of the Cloner object in sRGB color values. Display Color – The Display Color – , which is determined in the Basic properties of an object.
ID Ratio (Color) – The index ratio of the Cloner as a grayscale color value. Layer Color – The color of the layer that the object is placed in.
ID Ratio – The index ratio of the Cloner as a zero to one float value.
Index (Normalized) – The index ratio of the clone as a zero to one float value.
Weight – The MoGraph Weight attribute as a zero to one float value.
Clone Offset – The MoGraph Clone Offset attribute as a zero to one float value.
Time Offset – The MoGraph Time Offset attribute as a zero to one float value.
Falloff Weight – The MoGraph Falloff Weight attribute as a zero to one float value
Size – The Cloner's size attribute as a vector value.
UVW – The Cloner's UVW attribute as a vector value.
