||V-Ray Asset Editor|| > Create Asset (left-click) > Materials Generic
UI Options
width65%
The Generic material settings are organized in Basic and Advanced modes. You can switch the mode from the toggle button under the Preview Swatch or globally from the Configuration rollout of the Settings tab.
The Add Layer andAdd Attribute buttons are provided for some V-Ray materials, including Generic. For more information, see theAdd Attributeand Add Layer sections.
UI Text Box
typetip
Holding down Ctrl while having the Add Attribute or Add Layer menu open, allows selecting multiple entries without closing the dropdown.
The context menu of the Color slot provides options to Copy and Paste, as well as to Reset the color.
A Reset option is provided in the context menu of each Number Slider. You can reset the slider value to the default one.
UI Text Box
typenote
The blue indicator next to a rollout () indicates that the lead parameter of this rollout, which affects the final appearance of the material, is changed.
width5%
width35%
Expand
titleTranslucency
Translucency
Multiexcerpt include
SpaceWithExcerptVRHINO
MultiExcerptNameTranslucency Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Translucency Attributes
Expand
titleBump
Bump
MultiExcerptNameBump Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Bump Attributes
Expand
titleOutline
Outline
MultiExcerptNameOutline Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Outline Attributes
Expand
titleDisplacement
Displacement
MultiExcerptNameDisplacement Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Displacement Attributes
Expand
titleRaytrace Properties
Raytrace Properties
MultiExcerptNameRaytrace Properties Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Raytrace Properties Attributes
Expand
titleOverride
Override
MultiExcerptNameOverride Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Override Attributes
Expand
titleMaterial ID
Material ID
MultiExcerptNameMaterial ID Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Material ID Attributes
Layers
width4%
width25%
Thumbnail
ThumbnailTitleTextGeneric Multipliers
ThumbnailPageLinkhttps://docs.chaos.com/display/VRHINO/Generic+Multipliers
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Binding and Override ControlViewport Display
ThumbnailPageLinkhttps://docs.chaos.com/display/VRHINOVRHINO4EDIT/Generic+Binding+and+Override+ControlViewport+Display
width1%
width25%
width4%
