  • Closing the CAD during Multi-Asset Placement leads to Infinite Error Loop when you Choose to Apply and Leave: Error dialog is displayed only once and then Enscape quits.
  • Enscape Version Is Shown On Loading Screen With Customized Background Image: Enscape version is no longer visible on Customized Background images.
  • Invalid License Overlay Not Refreshing on New License Error: No valid license overlay is displayed.
  • Section plane is not applied after you edit it once: Section planes are now updated correctly.
  • Video textures skewed due to incorrect row alignment: Video textures are now rendered properly.
  • Renderer crashes in Korean: Renderer starts without crashing.
  • Enscape 4.5.0 Is Not Detected By New Version Check: New versions are now correctly detected.
  • [SketchUp] Document Isn't Properly Closed On Shutdown Leading to Log Spam: The exception on shutdown does not appear anymore in the sketchup plugin logs.
  • [SketchUp] Time of Day Resets When Creating a New View: The time of day remains the same after creating a new view.
  • [Vectorworks] Inconsistent global illumination: Resolved an issue where Global Illumination (GI) results varied between batch renders of the same views within the same session when using Hardware Ray-Tracing (HWRT) and Real-Time Sun and Sky (RTSS) in Vectorworks. GI is now stable and consistent across consecutive batch exports.
  • [Rhino] Stability Improvement for High-Quality Renders: Resolved a crash that could occur in quality levels above Draft when capturing multiple screenshots in close proximity to complex geometry, such as metal bars.
  • [Rhino] Cutout texture rotation does not reflect on the renderer when the mapping type is Worldplane/worldbox for Albedo: Cutout texture rotation now reflects on the renderer.
Known Issues
  • [Archicad] Fails To Register on Mac Due To Hebrew System Language.
  • [SketchUp] False Color Visualization does not work well with White mode overrides and breaks switching to None Mode.
  • Views in Artistic modes freeze Enscape window with 3D stereo mode enabled
  • HitGroup Index not calculated correctly
