Environment Override Examples
The below examples come from a single scene: A camera using a forest HDRI as the scene environment with a reflection override enabled so that there are no tree reflections in the water:
Another camera using a daylight HDRI as the scene environment and an evening HDRI as the reflection override:
Section | |||||||||||||||||||||||||
Overrides
Section | ||||||||||||||||||||||||||||||||
The following renders are from exactly the same scene. The volume is made from a simple water plane with displacement and surrounding walls.
