This page provides information about the VRayUserInteger texture in V-Ray for Cinema 4D.
HideElements | ||
width | 60% |
The VRayUserInteger texture allows the user to read and return a single integer value from the currently shaded object as a result. This can be useful if the same material or texture is applied to several objects in the scene, but you want to control some of its properties with user-defined properties. For more information on user-defined properties (i.e., User Attributes), see the User Attributes Workflow page.
UI Paths:
||Texture|| > plugins > V-Ray > VRayUserInteger
||Texture|| > V-Ray > VRayUserInteger
width | 5% |
Properties
Section | |||||||||||||||
