Progress Bar Container
step4
Progress Bar - Hyperlink Step
titleIntroduction
urlIntroduction to Vroom
titleRoad Design
urlRoad Design
titleTraffic Simulation
urlTraffic Simulation
titleVehicle Crowd
urlVehicle Crowd
titleRoad Properties
urlRoad Properties
titleIntersections
urlIntersections
width50%
The Vehicle Crowd parameters section is used to populate the roads with the vehicles from the library and to apply a different behavior to each one of them as they are generated. This includes essential aspects such as speed variation range, and decision-making at intersections (whether a vehicle is more likely to continue straight or make a turn).
Since these settings apply at the moment the vehicle is created, they will stay with the vehicle throughout its journey, even as it crosses intersections and moves onto other roads. This ensures that each vehicle maintains a unique driving style and decision-making process, making the simulation feel more natural and unique.
width5%
width45%
Image Added
Vehicle Crowd Generation
width50%
The fastest and easiest way to populate the roads with multiple vehicles from the library is using the GENERATE button along with the parameters available in the Crowd section.
The types of vehicle models that will be generated can be defined by selecting them in the library and adding them to the vehicle model list available at the top of this section:
width5%
width45%
