width50%
The Corona Scanned Material allows you to use Chaos Scans with Corona.
There are some materials that are impossible to recreate with any number of parameters and maps in a generalized material, as they have a unique way of responding to light. This is where VRSCANS comes in. Each material in the library is meticulously scanned to capture how it interacts with light so that you can drag-and-drop it into your scene for 100% accuracy in both look and scale.
UI Text Box
colorlight-cyan
iconinfo
Starting from Chaos Corona 12 Update 2, the Chaos Scans are available in Cosmos.
width5%
width45%
Tutorial: Chaos Scans with Corona for Cinema 4D
