ButtonDescription
Saves currently displayed image to a selected file.
Clicking the "arrow" icon next to the Save button displays the following available options:
Save– Saves currently displayed image to a selected file.
Save allSaves each multipass (including the Beauty pass) as a separate file using a specified file format.
Save CXRStores all the information from the VFB (including the multipasses, the LightMix information, tone mapping,
denoising data, etc.) inside a single CXR file. To learn more about saving CXR files visit our Help Center.
Copies the VFB content to the host app frame buffer.
Copies currently displayed image into clipboard.
Erases currently displayed image.
Activates mode for editing the render regions.
Clicking the "arrow" icon next to the Render Region button displays the following available options:
Disable All – Disables all selected regions.
Delete all – Removes all selected regions.
Activates pick mode for selecting objects and setting of camera focus point.
Hides/shows tools sidebar.
This drop-down list allows performing zoom actions.
Zoom in – Zooms the image in.
Zoom out – Zooms the image out.
Zoom to 50% – Zooms the image to 50%.
Zoom to 100% – Zooms the image to 100%.
Zoom to 200% – Zooms the image to 200%/
Lock IR resolution – This checkbox locks the image aspect ratio when the IR is running.
UI Text Box
typetip
Keyboard shortcuts are available for zooming actions.
Ctrl + + – Zooms in
Ctrl + - – Zooms out
Ctrl + 0 – Zooms the image to 100%
Double-click (LMB) – Changes the VFB size to match the image size.
Start Interactive Rendering – Starts the Interactive rendering feature.
Stops the rendering process without discarding any additional data or post-rendering actions.
UI Text Box
typenote
When denoising is enabled, pressing the Stop button stops the rendering process and proceeds to denoising post-rendering actions.
Clicking the "arrow" icon next to the Stop button displays the following available options:
Stop – This is the same as the "Stop rendering..." button in the Cinema 4D Picture Viewer window. (this is the default action for the Stop button)
Cancel – Stops the rendering process, discards denoising or post-rendering actions, and skips saving output files (if were set up).
Starts the production rendering process.
Clicking the "arrow" icon next to the Render button displays the following available options:
Render – Starts rendering process. (this is the default action for the Stop button)
Resume last – Resumes last render.
Resume File – Resumes rendering based on a previously saved CXR file.
Image RemovedImage Added
This drop-down list allows selecting the multi-pass to be displayed in the VFB.
width50%
Bloom & Glare
Anchor
C4D_VFB2_ByG
C4D_VFB2_ByG
Compute After Render If enabled, the Bloom and Glare effect is computed at the end of the rendering process, instead of during the whole rendering.
Size – Increases/decreases Bloom & Glare size.
Bloom Intensity – Increases/decreases bloom intensity.
Glare Intensity – Increases/decreases glare intensity.
Threshold Controls the minimum brightness which is considered for the Bloom & Glare effect. Increasing the threshold applies Bloom & Glare only to the brighter pixels. Reducing it allows the Bloom & Glare effect to be applied to pixels that are less bright.
Color IntensityControls how saturated the Bloom & Glare effect is. Higher values mean higher saturation.
Color ShiftChanges the hue of the coloring added to the Bloom & Glare effect.
Streak Count –  Defines the number of streaks for the glare effect.
Rotation – Rotation of the glare effect in degrees.
Streak Blur – Decides whether the glare streaks should be sharper or more blurry.
Custom aperture – Enabling this checkbox allows the use of the Editor button to fine-tune advanced Bloom & Glare options.
UI Expand
titleClick here to see the Custom Aperture Editor UI:
Sides – Sets the number of aperture blades used for custom aperture. When disabled, the circular aperture is used instead.
Rotation – Rotation in bladed aperture in degrees.
Streak Blur – Controls the blurring of the glare streak perpendicular to the streak direction.
Occlusion – Enables occlusion of part of aperture shape.
Ratio – Controls ratio of the aperture being occluded, with the minimum value meaning no occlusion and the maximum value meaning full occlusion.
Rotation – Controls the rotation of the occlusion in the degrees.
Curvature – The arc of occlusion with the minimum value being straight line and the maximum value being full arc.
Arc – The arc of occlusion with the minimum value being straight line and the maximum value being full arc.
Symmetric – When enabled, occlusion is applied symmetrically from both sides of the aperture.
Reset all – Resets the setting to default value.
Peripheral Grating – Enables grating along the sides of the aperture shape. This creates "halo" effect around lights in render.
Lens Scratches – Simulates scratches over the lens. Regular scratches can create additional glare effect, while irregular ones will effect affect shape and blur of existing glare effect.
Lens Dust – Simulates dust particles over the lens. Dust can create effect similar to bloom that is affected by overall pattern of generated particles.
width5%
width45%
width50%
Button
Description
Store Current VFB Stores the contents of the Store current VFB in contents into the history.
Loads content of a selected CXR file in the History – Loads a previously saved Load CXR file into the VFBhistory.
UI Text Box
typenote
Using the Corona VFB 2.0 allows for comparing images with different resolutions or aspect ratio.
Clear A/B – Disables the history comparison and shows the current render only.
Show currently rendered image – Restores the last rendered image into the VFB. This option is only available if another image stored in the History that is different from the last rendered image is loaded for editing.
Delete All – Deletes all items from the history and from the HDD.
Show with original postprocessing – Shows the stored content with original postprocessing.
UI Text Box
typeinfo
Additional actions can be performed on each individual image stored in the History. Available actions for images stored in the History are:
Show and edit this image reloads the selected image and editing its parameters one more time in the Post tab.
Save current render element saves the selected image stored in the History to a specific location.
Resume in rendering of the current scene using the selected image as the new starting point.
Clears the selected image from the History but not from the HDD.
Deletes the selected image from the History and also removes it from the HDD.
Uploads this item to the Chaos Cloud.
width5%
width45%
LightMix Tab
width50%
 After After at least one one LightSelect and one LightMix multi-passes are added to the scene, the interactive LightMix controls become active in the LightMix tab.
Additional actions can be performed for the LightSelect passes as follows:
Image Removed current Lightmix settings into the scene lights – Bakes the current Lightmix settings (intensities and colors) into the current Image Removed current Lightmix settings to a config file – Saves the current Lightmix settings into Image Removed Lightmix – Loads Lightmix settings from a previously saved file.Set colors to white – Sets all LightSelect colors to pure white color. Each LightSelect element can be manually adjusted using the individual color box to launch the Corona Color Picker
ButtonDescription
Image Added
Bake
currently set Lightmix colors/intensities into the scene lights.
Image Added
Save
settings of the current displayed light mix element to a config file.
Image Added
Load
light mix settings from a config file
Image Removed
Enable/Disable LightSelect elements – Enables or disables all configured LightSelect elements. If all entries or some of them are disabled, then this enables all of them. If all entries or some of them are enabled, then this disables all of them.
Image Removed
Set intensities to 1 – Set all intensities to a value of 1.0
Image Removed
to the currently displayed light mix element.
Image Added
Enables all entries if some are disabled or disables all if all are currently enabled.
Image Added
Set all intensities to 1.
Image Added
Set all colors to white.
Additional Tips:
  • LightMix colors can be copied by dragging and dropping a color swatch onto another swatch.
  • LightMix colors can be reset to pure white by right-clicking on a swatch.
  • You can also right-click on the light names on the LightMix list in the Corona VFB to select a specific light in the scene, add that light to the current selection, or remove that light from the current selection.
UI Text Box
typetip
When using the Corona VFB 2.0, multiple Lightmix multipasses can be loaded, allowing different setups for each Lightmix element.
width5%
width45%
width50%
Starting fromCorona 12 Update 1, Collaboration features from Chaos Cloud are supported in Corona for Cinema 4D. With the Collaboration tools, you can easily share drafts and final renders with customers and team members. The Collaboration tools from Chaos Cloud also support mark-up discussions, version control, and more, allowing for efficient and seamless project coordination in real-time.
To learn more about how to useCollaboration features from ChaosCloud, please visit this page.
width5%
width45%
