Post Tab
width55%
Image Added
Image Added
Saves current postprocessing settings into a file.Loads postprocessing settings from specified file .
width5%
width45%
Auto Adjustments
Auto Adjustment
Image Removed
width55%
UI Expand
titleClick here to see the Auto Adjustment UI...
Exposure– Calculates optimal exposure based on rendered values without tone mapping. To see what exposure values is generated, remove exposure operator(s) in tone mapping and bake auto exposure into tone mapping.
White Balance– Calculates optimal white balance based on rendered values without tone mapping. Bake to see the generated value.
Update during animation– If enabled, auto adjustments are calculated for each frame of sequence rendering. When disabled, auto adjustments are calculated only for the first frame of the sequence and stay unchanged.
width5%
width45%
Image Added
Tone Mapping
Image Removed
width55%
Image Removed
The Tone Mapping rollout lists the currentlyaddedTone Mapping Operators. By default, it includes the following operators:
  • Simple Exposure
  • White Balance
    UI Text Box
    typenote
    Starting from Corona 12 Update 1, the White Balance operator has been deprecated and is now called "Legacy White Balance." The new White Balance operator uses Bradford's chromatic adaptation formula, which makes it more accurate and in-line with industry standard.
  • Green-Magenta Tint
  • Contrast
  • Saturation
  • ACES OT
"+" button– Displays the list of all available Tone Mapping Operators and allows to add one.
Reset button– Resets the current Tone Mapping Operators stack to the default configuration.
Presets button– Displays the list of built-in tone mapping presets.
width5%
width45%
Image RemovedImage Added
UI Expand
titleClick here to see the full list of tone mapping operators...
width55%
Sharpen amountThe value that is used to control sharpening.
Sharpen radiusDefines the sharpness radius.
Blur radius  Defines the radius of blur.
width5%
width45%
width55%
Denoise amount The main value that is used to control denoising. It blends between the original (noisy) image and the fully denoised version of the image, where 0 is the original image and 1 is the purely denoised version.
width5%
width45%
